Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   Engine Swaps, Tech & Tuning (https://www.honda-acura.net/forums/engine-swaps-tech-and-tuning-33/)
-   -   Turbo'n my LS (https://www.honda-acura.net/forums/engine-swaps-tech-and-tuning/283790-turbon-my-ls.html)
NITSVP Jan 5, 2008 07:25 PM
Turbo'n my LS
Ok i am pretty good with working on cars and stuff and i can pretty much do anything as long as i have instructions but i plan on turboing my 94 teg ls coupe and i know i have to buy these items is there anything else i need besides this stuff?
1x JDM TURBO T3/T4 .60 A/R
3" Outlet
Wet Floating Bearings
1/8 NPT Oil Inlet ,T3 / T4 Flange
Fits T3 And T3/T4 Manifolds
. 48 A/R Compressor ,60 A/R Turbine,60 Trim
This Turbo Can Easily Do 25 psi
1x TURBO MANIFOLD
T304 IRON CAST Racing Manifolds
OEM quality. CNC Machine Flinges
lightweights Designed. Increase 12HP
02 Sensor insert. Gaskets included. Direct fit
1x WASTEGATE
38mm wastegate w/ hardware
Cast from 253MA Stainless Steel (ASTM S30815)
Withstand high temperature and flow capability
Adjustable Spring rate with boost controller
1x OIL LINE FEED KIT
Designed to limits oil flow
Prevent blown oil seal
36 inch long with 3/8 diameter stainless steel line
Hardware and gasket is included
W/ 1/8 inch fittings for the engine
O yeah i forgot to add the intercooler and the piping for the intercooler. What else?
Provocateur Jan 6, 2008 08:45 AM
Sounds like an ebay kit. Buy quality parts or don't even bother.
WTF is a JDM turbo? And you would really trust boost to be regulated correctly with a no-name wastegate?
You will also need oil drain, downpipe, larger injectors, fuel management, bov, possibly gauges. Your list is missing a lot of essential items.
© 2026 MH Sub I, LLC dba Internet Brands
