change in plan
Old Dec 31, 2007 | 07:00 PM
jeff_falk2007's Avatar
jeff_falk2007
Default change in plan
sorry...lol i dont know very much about the honda engine. just tell me what i can do with 12,000$ and want something that wont blow up on me....what would you suggest? i want to run a 10 second car...less if i can accomplish it
Old Jan 3, 2008 | 10:00 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Here is a basic rundown of what you will need:
Light chassis
B,H,K series motor
Iron Sleeves
Low compression pistons (9:1)
Forged rods
Valves, valvesprings, and retainers
Turbo capable of 500+ whp
1600 cc injectors
Engine management
If you don't cheap out on parts and build it properly, it will last a good while.
Old Jan 3, 2008 | 11:17 PM
jeff_falk2007
Default questions
my car is a 1994 integra ls 4 door....and has the B18B1 engine...and am currently looking for a MT....i need a suggestion on a Manual Trans and where to get one. Should i upgrade to vtec? are there any tutorials to successfully install and run a turbo if so then where can i get one? where are tuning shops around the ohio region? should i change my stock ecu? the help is appreciated.
Old Jan 4, 2008 | 06:46 AM
Provocateur
On permanent hiatus
You are going to need a lot of power to haul that pig of a chassis into the 10's. You want a short geared tranny but not so short geared that you have to shift into 5th before the end of the race. A GSR tranny should be perfect. Converting to vtec will help reach your goal a lot easier.
You are going to have to google the answers to the rest of your questions. If you want a car in the 10's, you would certainly be more proactive on finding information.
