wastegate
Old Dec 12, 2007 | 10:53 PM
acuraturbo's Avatar
acuraturbo
Default wastegate
i need help with a problem i got with the external wastegate....well the pipe on the manifold makes the wastegate go to the same side as the intake for the turbo...should i cut and change it to the other side of the turbo on the exhuast side of it or should i just bend the dump pipe a little so it wont be in the way of the intake?
Old Dec 13, 2007 | 06:08 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Sucking up vented wastegate gases back into the motor will cause substantial power loss. Get the pipe far from the intake filter.
Old Dec 13, 2007 | 12:45 PM
acuraturbo's Avatar
acuraturbo
thanks i kinda knew that but wanted to make sure first....thanks a mil..
