turbo and nos
hi i have a question i have a 94 acura integra with a greddy turbo kit and i'm boosting 11 psi i wanna get some more hp but since i have a stock map sensor i can't crank up the boost so i wanna put my zex nos kit on and spray threw the intecooler would can i use co2 or does it have to be nos and would it make a difference anyone can help me thanks
if your air filter is behind or even close to your ic if you spray co2 and your engine sucks it in it wont make ans much power, if you use nos for the sprayer and a little gets in the enigne it might make a little difference. what mangament are ya using.
i don't have a filter on my turbo i had one but took it of i know its bad um i have 450cc injectors and fpr is that what u mean't as management unit or do you mean the computer i have a chipped ecu i also have a aem fuel ratio guauge when i'm at full throttle it reads low 11s or high 10s
yeah if you have no tuning then it doesnt matter what ur map sees. i strongly recomend a s100b or somthing like that its way way safer and you dont have to burn up ur fuel pump or hurt ur injectors to bad.
on another note have you dynoed it? if so what are the #s
