Valve clearance
Old Oct 28, 2007 | 03:54 PM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Default Valve clearance
Ok i have these parts
*B16a1 head with 30 thou skimmed off it)
*B16a1 block
*b16b pistons
*b16a rods
*s2s2 cams
*AEM cam gears
*cometic 0.030 head gasket
I have worked my c/r out to be 11.81.1
Will i be able to set it to standard timing settings with out the valves
touching the pistons?
It will be going to be RR tuned asap, i just wana make sure it'll start and
run fine to get there.
Old Oct 29, 2007 | 10:48 AM
B16a2VTIguy
Built B16a
Anyone?
Old Oct 30, 2007 | 12:06 PM
18crx's Avatar
18crx
stock booster
well you should i belive set them to spec even with stock cams. i did on my car and it runs fine. and if your valves touch your pistons you have other problem like tbelt advanced a tooth or more or even retarded a tooth or 2. im sure its too spec. if not you wouldnt be using the cams to there potental.
Old Oct 30, 2007 | 12:09 PM
18crx's Avatar
18crx
stock booster
oh by the way did you clay the head to make sure they werent going to hit anyway before you did a final assembly. did you relief the pistons at all for the valves. if you didnt clay it i sure would to make sure it doesnt rattle rattle and not run.
Old Nov 6, 2007 | 06:31 AM
B16a2VTIguy
Built B16a
Well i havent even pre build assembly yet tbh, still waiting on parts to come back (head being skimmed and block being cleaned) But i will do those before i build it now thanks.
So do i set it to stock timing? if not how do i work out how to set the timing with these parts fitted?
Old Nov 6, 2007 | 11:32 AM
18crx's Avatar
18crx
stock booster
yes set the valve lash to stock settings.
Old Nov 7, 2007 | 12:33 PM
B16a2VTIguy
Built B16a
cool thanks
