Wastegate Woes
Old Oct 8, 2007 | 12:03 PM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
Default Wastegate Woes
Does anyone know where I can get the part circled in red in the included picture? My wastegate is a 38mm Turbosmart Ultra-Gate and it's missing that piece...I beleive it goes in the wastegate port against the header and it seals the piston to the gate body so that it fully closes, without it it will leak exhaust through the dumptube all the time and fully open at full boost...I lost on where to get something like this, I may just make one with two spacers and some custom cut gaskets from the DIY gasket material.
Thanks in advance!
Old Oct 8, 2007 | 03:54 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I don't see a picture but I believe you are referring to the fire ring. Your best bet is to call up the manufacturer and see if they can sell you just the part you need. I wouldn't attempt to make your own. If it is anything like my Tial, it is a close interference fit with the wastegate itself.
Old Oct 9, 2007 | 06:41 AM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
Whoops, sorry bout the pic, I forgot to upload it but it's right here. I guess I'll try to get ahold of Turbosmart today..
File Type: jpg
Old Oct 9, 2007 | 06:47 AM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
I found these at their site, they refer to it as a valve seat.
Ultra-Gate 38 Hi-Temp Accessories: Part number
Garrett 32 adapter FG-WG38-AGRT
KKK (small) adapter FG-WG38-AKKK
Spring 3psi outer FG-WG38-SP03
Spring 5psi outer FG-WG38-SP05
Valve Locking Tool FG-WG38-VLT
Double Flange Kit (stainless) FG-WG38-DSF
Pressure Line adapter FG-ADA-DASH4
Ultra-Gate 38 Spares: Part number
Silicone Nomex Diaphragm FG-WG38-DIA
Belpa Mica Manifold Gasket FG-WG38-GSKT
Double Flange Kit (mild steel) FG-WG38-DWF
Spring 7psi inner FG-WG38-SP07IN
Spring 7psi outer FG-WG38-SP07
Spring 10psi outer FG-WG38-SP10
Valve Seat FG-WG38-SEAT
Old Oct 9, 2007 | 06:55 AM
Provocateur
On permanent hiatus
I want to say it is the Valve Seat but I can't be sure. Again, it would be most helpful to call them up and make sure you get the right part.
Old Oct 9, 2007 | 09:53 AM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
I found a picture of one, that's it! But $38+ shipping from spooledmotorsports.com sucks, but I gotta have it, my radiator and slim 14" fan just got here from Mishimoto, and $40 isn't gonna stop me from finishing this project, so I just ordered it.
http://www.aetturbosonline.com/catal...eat-p-536.html
