Best intake/ throtle body/ cam combo 4 a b16
Old Sep 5, 2007 | 04:08 AM
1 quick sol's Avatar
1 quick sol
Default Best intake/ throtle body/ cam combo 4 a b16
Hey guys, i just wanted to get your thoughts on the best Intake manifold out there for a b16 turbo charged setup? I've been looking at skunk2 pro series, i've heard the edlebrock performer is much better? From what i've gathered probally use a 68mm throlebody? Last but not least Camshafts? It's turbo so nothing to crazy, i am running aftermarket stocks size valves, and skunk2 dual valve springs and retainers, had stage 3 pro series cams, way to much for the turbo set up. What about Civic Type R's? Or does Brian Crowler make a good cam for a turbo motor? What kinda duration should i be looking for, by the way i already have skunk2 gears and greddy timing belt so any thoughts would be appriciated, thanks scott
Old Sep 5, 2007 | 12:19 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
Edelbrock Victor-X manifold is the popular choice for the turbo setups. The skunk2 is a Type-R manifold for N/A setups.
Skunk pro series cams are set up for N/A. Look into the Skunk2 turbo cams.
Civic Type R cams are made for N/A with high compression.
Old Sep 7, 2007 | 08:30 PM
Snoopy's Avatar
Snoopy
been there done that
itr/ctr cams do very well with boost. and they're cheap.
the edelbrock victor x manifold does very well for high boost, high revving setups.
