help swap my stock p72 with skunk2chipped p30
Old Sep 3, 2007 | 01:28 AM
greenmachine619's Avatar
greenmachine619
Default help swap my stock p72 with skunk2chipped p30
wassup peeps..im kinda new to this......
i have a 2000 integra gsr with a stock obd2 ecu
i wanted to swap it out with a skunk2 chipped p30 ecu
i have obd1-obd2 conversion harnest.
will this work????
will i have problems????
whats the propper way to swap them out??
any pros and cons????
thanks!!!
Old Sep 3, 2007 | 10:23 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Why? The Skunk2 pre-programmed chip is garbage.
Old Sep 3, 2007 | 10:29 AM
greenmachine619
i dont know..ahhah it just came with the p30 ecu.......
was just wondering if its going to work with my car with out any problems
Old Sep 3, 2007 | 10:36 AM
Provocateur
On permanent hiatus
If you can look past the poor performance, decreased fuel efficiency, and no IAB support, there won't be any problems. You will need an OBD2b to OBD1 conversion harness and the ECU.
If you have a setup that needs tuning, get it properly tuned. If you don't, leave the ECU stock. Nothing but headaches will result from unnecessarily messing with the ECU.
