DC Sports 1 piece ceramic header install question
Old Aug 10, 2007 | 01:28 AM
nonbox's Avatar
nonbox
Default DC Sports 1 piece ceramic header install question
I have a 94 GSR with a thick fluidine radiator. Do I have to remove the radiator in order to install a DC Sports 1 piece ceramic header?
Old Aug 10, 2007 | 05:27 AM
primetime's Avatar
primetime
no, you shouldn't have to remove that radiator to put those in!
Old Aug 10, 2007 | 06:42 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
I would remove it since the room you have to work with is minimal enough with a stock radiator. If you don't remove the radiator, you will probably have to unbolt the slave cylinder and move it out of the way to squeeze the header up there.
Old Aug 10, 2007 | 02:33 PM
KaoticBRD's Avatar
KaoticBRD
I would remove the radiator give yourself as much room as you can. You don’t want a scratched up header.
Old Aug 10, 2007 | 05:30 PM
nonbox's Avatar
nonbox
What if I tape an old towel over the radiator to not scratch the header?
Old Aug 11, 2007 | 09:37 AM
KaoticBRD's Avatar
KaoticBRD
If you need to keep the radiator in I would at least remove the fans. And be sure to put the header in from the bottom.
Old Aug 11, 2007 | 01:33 PM
nonbox's Avatar
nonbox
Here's the install with pictures. Looks like radiator & fan doesn't have to be removed:
http://www.clubcivic.com/board/showthread.php?t=58482
