b18a1 vs b18b1?
Old Jun 1, 2007 | 07:47 PM
Hot1990civ's Avatar
Hot1990civ
Default b18a1 vs b18b1?
Just looken for facts or opinions on the difference of them i know it has been covered in other threads just a question for you guys, because my teg had a b18a1, but im dropen a b18b1 in tomorrow.
Old Jun 1, 2007 | 07:49 PM
Snoopy's Avatar
Snoopy
been there done that
b18a is obd1. b18b is obd2. other than that nothing major.
Old Jun 1, 2007 | 07:51 PM
Hot1990civ's Avatar
Hot1990civ
does that mean i need a diff ecu for the swap?!?
Old Jun 1, 2007 | 07:54 PM
Snoopy's Avatar
Snoopy
you'd need the ecu that originally ran the engine
Old Jun 1, 2007 | 07:57 PM
Hot1990civ's Avatar
Hot1990civ
So your telling me the one that is in the car from the a1 wont run the b1
Old Jun 1, 2007 | 08:26 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
As long as the A1 ECU is from a 92-93 motor and the donor motor is a 94-95 motor. Otherwise, you will have to buy an OBD2 computer to run that engine unless you run an OBD2 to OBD1 conversion harness.
Moved to Engine Swaps.
Old Jun 5, 2007 | 04:07 PM
Hot1990civ's Avatar
Hot1990civ
will the car not start if everything isnt right?
Old Jun 6, 2007 | 08:29 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
The B18A1 motor came in the '89 - '93 Integra's. The '89 - '91 cars are pre OBD or OBD 0 (meaning they have a very simple electronic ignition and ECM/emissions package). The '92-'93 B18A1 (I think they're still a B18A1) are OBD I and have a far more extensive amount of engine harness wiring and better emissions controls. The '96+ Integra motors (and all cars per the US Government) are OBD II and again have more wiring and more advanced ECM's.
If your planning to drop a B18B engine in your DA Integra (which is most likely pre-OBD) your easiest solution is to convert the B18B over to a pre-OBD engine. That means transfering the sensors, injectors and distributor from your old engine over to the new one. The B18B's existing engine wiring harness will (most likely, I don't know all the details here) not plug into your in-car harness and the car will not start.
What year is your car and what year is the engine you will be getting?
Old Jun 8, 2007 | 08:28 PM
Paulll's Avatar
Paulll
Hail Bent
Not all b18b's are obd2, I have an OBD1 in my garage right now
b18b1 are from the early db's. b18b2 are a little newer
