94 jdm gsr into 92 gsr engine light problems
Old May 29, 2007 | 01:00 PM
bpruett84's Avatar
bpruett84
Default 94 jdm gsr into 92 gsr engine light problems
i swapped a 94 jdm gsr motor into my 92 gsr and used the old wiring harness but new ecu. i am getting a check engine light for the knock sensor and electronic load detector. there is not an eld on a 92 gsr. can anyone point me in the right direction to getting rid of these lights? (when the engine light comes on i lose 40-50 horsepower, happened on the dyno.)
Old May 30, 2007 | 11:43 AM
jesusublime99's Avatar
jesusublime99
I thought 92 GSR engines came with Knock Sensors.... if not, you just need to plug in a Knock Sensor into your motor and plug that wire directly to D3 on your ECU harness at the ECU. I got one from Rywire.
I did the same swap in a 92 LS, the ELD CEL went away with new battery terminals and a new battery, my friend's terminals were corroded.
Old May 30, 2007 | 03:33 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Moved to Engine Swaps.
