Need Help !!***!! w/ 1994 LS With Gsr Head and B20 Block
Old May 20, 2007 | 06:02 PM
Tkewtn's Avatar
Tkewtn
Default Need Help !!***!! w/ 1994 LS With Gsr Head and B20 Block
I have a 1994 5 speed ls coupe with a new b20b motor and gsr head
Its running a p30 ecu
Just bought it but its been ghetto rigged
Got a new gsr distributor
But everything else like the engine harness is from the old ls
What will I need to finish this swap?
Just bought new mounts
New dizzy
My friend says I need to buy a gsr harness and a gsr dash harness
These are pretty hard to find for me, are there any other kinds of harnesses and dash harnesses that I can use besides a gsr?
Any help would be great!
Old May 21, 2007 | 05:58 AM
primetime's Avatar
primetime
it is alot easier to find or buy a gsr engine wiring hareness and using that if you don't have experience wiring the vtec! did you buy gsr mounts?? is the
p30 chipped?
Old May 21, 2007 | 09:15 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
You can use the existing harness. Just run wires for vtec and you will be fine.
Old May 21, 2007 | 02:33 PM
Tkewtn's Avatar
Tkewtn
Thanks again for the quick replies.
I have one more question, my friend says the v-tech does kick in, but at 5,500 rpm
Is there anyway to fix that?
Old May 21, 2007 | 03:03 PM
Provocateur
On permanent hiatus
It should be engaging around 5500 with that ECU. Unless you chip it or buy a vtec controller, it will stay at 5500.
Old May 21, 2007 | 06:14 PM
Tkewtn's Avatar
Tkewtn
Thanks a lot for all your help
I will definitely get to work on it and if any questions pop up, i'll pm you
Thanks again
Really appreciate it
