Safe Boosting?
Old May 15, 2007 | 04:00 PM
FearTheTruth34's Avatar
FearTheTruth34
Default Safe Boosting?
got a 1995 ls teg with 170k on it, runs great, burns not an ounce of oil, clutch never slips, this summer i am going to be buying a new b18b and building it, but was wondering if it would be safe to boost my current motor on say 3-5 psi?
Old May 15, 2007 | 06:51 PM
Snoopy's Avatar
Snoopy
been there done that
focus on a power level. hp breaks stuff not psi. 250-300whp would be safe on that engine.
Old May 16, 2007 | 06:33 AM
primetime's Avatar
primetime
I agree with snoopy, but why don't you focus on buying the b18b and building that for boost! By not boosting the current motor and focusing on your project you can build the b18b faster and have a great running back up that you can keep just incase anything happens to your built motor or you can sell it later on just to have extra cash on hand!!!
Old May 16, 2007 | 05:39 PM
KaoticBRD's Avatar
KaoticBRD
I would say mybe 5 to 7 or nothing on a 170,000 mile motor. On your built up ls motor I'd say at least 15lbs should be safe. I'd save the turbo for a newer built motor.
Old May 18, 2007 | 11:47 AM
18crx's Avatar
18crx
stock booster
bah i have an ls turbo thats been turboed for 2years and it had 190k on it when i turbed it. and i ran at the track last weekend on 13-15 psi. daily runs 10psi. and i daily drive it.
Old May 24, 2007 | 10:26 AM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
Woohoo, that's good to hear! My 2000 LS has 85K on it and I'm going to be running 10psi very soon.
Old May 25, 2007 | 11:20 AM
18crx's Avatar
18crx
stock booster
oh one thing i have that i recomend is arp rod bolts.
Old May 27, 2007 | 07:00 AM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
How necessary are the rod bolts? I will be fine on < 10psi with stock internals, yes? That's what I keep hearing.
Old May 27, 2007 | 09:23 AM
Snoopy's Avatar
Snoopy
i'd worry about getting arp bolts if you wanted to rev higher
Old May 28, 2007 | 09:41 PM
2001TEGGSR's Avatar
2001TEGGSR
Please read below.
With a larger turbo, 9 psi could put 375 hp down.
With a smaller turbo, 20 psi could put 280 hp down.
PSI is irrelevant, it only tells you the pressure buildup in your intake manifold. You must take into consideration the actual amount of air flowing (CFM).
