1988 Integra LS Special
Old May 13, 2007 | 05:47 PM
Amir's Avatar
Amir
88_Integra
Default 1988 Integra LS Special
What can I do to the Stock Engine to get more horse power?
Old May 13, 2007 | 05:53 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
If I remember correctly, that model year was pretty much a lost hope. Engine swap is the answer.
Old May 14, 2007 | 08:13 AM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
SEARCH. This site is chock full of info for simple mods to 900whp monsters. Money is speed, how much do you wanna spend?
Old May 23, 2007 | 05:23 PM
theturbocrx's Avatar
theturbocrx
Default mods
That engine should be the d16a1 right? You can get a skunk2 throttlebody and intake manifold, BDL fuel rail, universal fuel pressure reg., walbro 255lph fuel pump, injectors, pacesetter headers or you can get some for a 88-91 honda crx and port the headers to match the ports on the d16a1 ( not needed unless you want the most hp out of the headers), ignition upgrade, gude performance cam and head packages up to 50 hp gain. and a 1.5 sec drop in you 1/4 mile time, turbo, muffler, ram/cold air intake,. this should be enough to get you started. you can get most of these parts from Nopi.
Old May 24, 2007 | 05:31 PM
Snoopy's Avatar
Snoopy
been there done that
all that and you'd be lucky to break 120whp :down:
Old May 26, 2007 | 12:25 PM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
You could swap in a b series motor using the hasport kit or run some dohc ZC parts in the motor such as cams and use high performance pistons for other d series motors.
Old May 31, 2007 | 12:53 AM
nonbox's Avatar
nonbox
b16a2 swap but you will need a plasma cutter to cut away some metal on the driver's side because the altenator bracket will get in the way.
Old Jun 8, 2007 | 01:12 PM
jrw1818's Avatar
jrw1818
i bought a 88 integra ls once an i took the motor out an was gonna put my b20 motor in it but that cars motor mount shit is weak an all that torque would not be able to handle it lol
