torque??
Old May 6, 2007 | 12:35 PM
ianlee420's Avatar
ianlee420
94teggsr
Default torque??
anyone know a good way to build a b18c1 for torque? 170 hp n 129 ft. lbs. don't seem like much jus seeing if anyone had an idea how to build one for torque? do you need higher commpression? a turbo? thanks to anyone replying!!
Old May 6, 2007 | 12:45 PM
Snoopy's Avatar
Snoopy
been there done that
boost and/or lots of displacement
with all motor builds torque seems to max out at 160-170 with 2-2.2L displacement.
boost it and you can make as much as the engine can handle.
Old May 8, 2007 | 02:34 AM
ianlee420's Avatar
ianlee420
94teggsr
kind of hard to get much displacement from a b18 , so i guess i'll have to boost how much psi could a stock b18c1 handle??
Old May 8, 2007 | 05:37 AM
primetime's Avatar
primetime
Companies Make a 89mm, 92mm, and 95mm Crank for b18a/b/c1-5 blocks, lack displacement isn't the issue, price is the issue!!!
10psi to be on the safe side on a stock block.
Old May 8, 2007 | 01:14 PM
2001TEGGSR's Avatar
2001TEGGSR
Boost pressure is irrelevant.
A stock block can handle about 300 whp, run as much pressure as it takes to reach your goal. It might be 8 psi on a larger turbo, or 20 psi on a smaller turbo. CFM has more of an influence on horsepower and torque.
Old May 10, 2007 | 03:24 PM
ianlee420's Avatar
ianlee420
94teggsr
so if i wanna go over 300 whp i need different rods n pistons?,Sleeves? crank should be ok though right?
Old May 10, 2007 | 05:48 PM
2001TEGGSR's Avatar
2001TEGGSR
Forged pistons & rods will safely make 400 - 450 whp. Add sleeves and your potential shoots to the 600+ mark.
Honda cranks have proven strong in applications approaching 800 whp.
Tunning is key, one wrong move and your setup is toast.
Old May 11, 2007 | 02:25 AM
ianlee420's Avatar
ianlee420
94teggsr
will the hondata s300 provide me with what i need for a good tune??
Old May 11, 2007 | 06:41 AM
primetime's Avatar
primetime
YES!!! Just make sure you add the boost option when you buy it!!!
Old May 11, 2007 | 07:49 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
The S300 has the boost feature built in. It isn't like the S200 where it has to be purchased separately.
