F20B 97-98 Long Block
Old Mar 30, 2007 | 09:42 AM
fresh860's Avatar
fresh860
non-vtec
Default F20B 97-98 Long Block
wha type of motor is this an what is it out of?? will it fit in my 94 teg?? i found it for 1300$ with 30k comes with :Motor
-Alternator
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
Motors average 30,000 miles and come with a 100% start up warranty. All Sensors are guaranteed not broken and in working condition!
so wha should i do?? im thinking bout buying if it will fit
Old Mar 30, 2007 | 10:30 AM
Snoopy's Avatar
Snoopy
been there done that
it'd be as hard as an h22 swap
Old Mar 30, 2007 | 01:51 PM
fresh860's Avatar
fresh860
non-vtec
ok that tells me alot?? what motor is that?? what does it come out of? and what else would i need to complete that swap?
Old Mar 30, 2007 | 02:00 PM
Snoopy's Avatar
Snoopy
from what i can tell they're from jdm accord SiR's
Old Mar 30, 2007 | 03:28 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Moved to Engine Swaps.
Old Mar 31, 2007 | 10:32 AM
fresh860's Avatar
fresh860
non-vtec
now is that a good motor?? whats the numbers that it would put down stock?? how are would the swap be?? what else would i need?
Old Apr 1, 2007 | 07:39 AM
imperialcustoms's Avatar
imperialcustoms
the motor is from an Accord Sir 97-01 i believe it has
• Horse Power: 200 @ 6800rpm
• Torque: 147 lb-ft @ 5600rpm
• Redline: 7200rpm
is is basicly the the same as an H22 {the H22 may be cheeper}
i would search for a list of wut u need 4 an H22 swap it will be the same for this motor hears some off the top of my head....
H22 mounts for your teg
P13 H22 will work {unless ur getting an ecu with it}
if it dosent have a trans H/F accord/Prelude trans will work
i would also get a H23 manuel timing tensoner
if ur car is 0BD1 that motor is 0BD2 so get a jumper harness
there is some other small stuff but on a scale of 1-10 i would say its about a 6 if u have never done a swap yourself i would have someone help u. even though the H22 is probly cheaper i dont see to many people running the F20 so i say do It
