what is this part called and where can i get it cheap?
is this the IAVC?
http://img201.imageshack.us/img201/6...eedthisxx4.jpg im in san antonio. zip code 78240 |
yes
Definitely not Gunn Acura, or Gunn Honda - they charge list price for everything! Are you sure you need a new one? Sometimes they can be cleaned with brake parts cleaner.
Try: http://www.hondazone.com/ |
yep. already sprayed it out w/ carb cleaner something fierce!
my friend next door just HAPPENS to have a 93 prelude w/ an h23 in it. i took his and put it in mine, no surging idle. i put mine back in, surging idle. |
i gave it another shot of carb cleaner just now. im gonna let it soak for about an hour then resoak it and spray the crap out with a can of compressed air i have. the allen screw on the outside is completely stripped and i cannot adjust it further. im going to try some creative methods to tighten/loosen it.
the one i swapped in earlier this evening adjusted just fine, so i know somethings up with mine. |
Originally Posted by TheImportsRacer
(Post 3421467)
the one i swapped in earlier this evening adjusted just fine, so i know somethings up with mine. I've had to buy a few things locally, Gunn Acura and Honda both wanted list for everything! Never would give me any sort of a break, so I only go there if its absolutely necessary that I have the part right then and there. You might ask Advance or Pep boys, they might be able to get an IACV as well. Good luck! |
lm going to give it one last shot with carb cleaner and see if that helps. the last round of carb cleaner h elped alot. if i feather the gas, itll eventually idle normally at a stop light.
so i think one last shot (maybe 3rd times a charm?) of carb cleaner for this part. if it doesnt work, im going to look online for one... and if i cant locate one, buy it new for 180 from honda parts unlimited. |
dont know exactly if this 1 will fit....but take a look...
cgi.ebay.com/ebaymotors/92-93-94-95-96-PRELUDE-H22-IACV-IDLE-AIR-CONTROL-VALVE_W0QQcmdZViewItemQQcategoryZ33557QQitemZ12010 3437432QQrdZ1QQsspagenameZWDVW here is another that looks to be more like it... http://cgi.ebay.com/ebaymotors/Honda...spagenameZWD1V |
the first one will fit, its a DENSO aftermarket IAVC. doesnt matter about the connectors though (for coolant, i bypass that). all i need is one thats working, not broke like mine :)
