B18C5 and LSD trans problems
Old Feb 26, 2007 | 11:15 AM
HybridDriver's Avatar
HybridDriver
not the electric/gas kind
Default B18C5 and LSD trans problems
Hello everyone, im new here Just thought I'de ask for some help from you guys before I blindly go an try to trouble shoot the problem myself in the garage:
last thursday, my car's trans stopped being responsive. I had a new clutch and flywheel installed less than a year ago and the car worked fine. After a couple months, steering wheel vibrations would occur ONLY if I was turning with the car in gear (as opposed to just turning with the forward momentum, and the car in N). So I was at work, went to lunch no problem, then as I was parking the car, the trans stopped working.
It will idle fine, but the second i slip the clutch past a certain point, its like if i would have depressed the clutch all the way in, and the car stops moving. If i keep slipping the clutch past that point and give it some gas... you can sort of hear some contact trying to be made in the trans, and a loud sort of muffled sound comes from within the engine bay.
im gonna check the tranny oil which was replaced less than a year ago, but other than that im thinking that the shop i took it to last time didnt do the best job of installing the parts in the fist place, because I didnt beat on that clutch at all, and theres no reason why it shouldnt be working now.
-any help is appreciated.. thanks.
Old Feb 26, 2007 | 11:18 AM
HybridDriver
Default ooops
forgot to mention basic info:
1996 Honda Civic Dx Hatchback
1996 b18c motor with LSD trans
about 40000 miles on the motor
-short shifter installed
Old Feb 26, 2007 | 03:51 PM
micha177's Avatar
micha177
did you check the axles..is one broke
Old Feb 26, 2007 | 05:50 PM
HybridDriver
Would a broken axle still let the car idle tho? I havent checked them, but The car was was able to take me around to a restaurant and back before it crapped out when I was parking. If an axel broke, wouldnt it loud, or obvious?
Old Feb 27, 2007 | 01:48 AM
micha177's Avatar
micha177
not always, mine broke last week while i was driving and all i noticed was the car was pulling real hard to one side. i was able to drive until i finally stopped and then it wouldnt move again. my car still starts and idles, it just doesnt move.
Old Feb 27, 2007 | 07:56 AM
HybridDriver
thanks a lot for the info man... i just got the same opinion from my mechanic buddy. He said that the car probably wouldnt move at all, unless the transmission is LSD (which it is). I guess a busted axle is a lot better news than a busted clutch or flywheel. Thanks for the help,
-i'll keep ya posted
Old Mar 6, 2007 | 03:38 PM
HybridDriver
After raising the car, and inspecting the axles... one was definately damaged and the other looks okay.
some pics:
this is the driver side Axle :
http://img.photobucket.com/albums/v2...MAGE_00053.jpg
as you can see, the boot is pretty chewed up. Thats getting replaced. However, it still turned when I turned the wheel.
Passenger side:
http://img.photobucket.com/albums/v2...MAGE_00055.jpg
The passenger side looks fine, although where the axle meets the tranny, its pretty wet with oil. As you can see in the pic, theres a small gap between the axle and the tranny.
I have never had to repair an axle before, should the passenger side have that gap there? I ordered the parts and plan to swap them out friday, but any imput you may have would be a great help.
