lsvtec turbo
Old Jan 28, 2007 | 05:56 PM
ls_on_boost's Avatar
ls_on_boost
ls_on_boost
Default lsvtec turbo
hi what computer do i have to run in my 94acura integra to run ls vtec turbo right now it's turbo and i have a computer that's chipped do i need to change it i heard that i can let that compute and just buy vtec controler to pop the vtec but i don't know i wanna do it right so please let me know
Old Jan 28, 2007 | 06:11 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Any OBD1 vtec ecu will work if you aren't already running one. You don't need a vtec controller if it is chipped...the vtec engagement points are adjustable with the rom editor you are using.
Old Jan 29, 2007 | 10:39 AM
Snoopy's Avatar
Snoopy
been there done that
you can convert your current ecu to run a vtec engine
www.pgmfi.org
Old Jan 29, 2007 | 06:16 PM
ls_on_boost
ls_on_boost
i have an obd1 that's chipped but non vtec so if i use this computer i have to buy a vtec controller or?????
Old Jan 29, 2007 | 07:19 PM
dubcac's Avatar
dubcac
I
He can even use a nonvtec ECU if it's properly converted.
Old Jan 29, 2007 | 08:44 PM
Provocateur
On permanent hiatus
True. I forgot about that minor detail. h:
Old Jan 30, 2007 | 11:03 AM
Snoopy's Avatar
Snoopy
you're not reading the responses
Old Jan 30, 2007 | 11:49 AM
Running925's Avatar
Running925
Your Powder Coater
As stated above, obd-1 vtec conversion kit will be needed, probably your most cost effictive solution. After this, you will just need re-tuned / different map.
OBD1 ECU VTEC Conversion Kit ($19.00 + ship)
http://xenocron.com/products.php?page=chippingkits
* I, in no way recieve any benifits from this location for posting this link to the store.
