need help with crankshaft pulley
Old Jan 26, 2007 | 06:28 PM
vetset63's Avatar
vetset63
Default need help with crankshaft pulley
hello i have a 92 accord and i cant get the pulley off. eny advice.
Old Jan 26, 2007 | 06:55 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
What have you tried so far?
If you can't get a breaker bar on it while the car is in 5th with the brakes depressed, try soaking it in PB blaster first. Try getting as much leverage on it as possible.
If all else fails, take it to a tire shop/mechanic and I'm sure they won't mind zipping it off with an impact gun and tightening it just enough to get it loosened when you get home.
Old Jan 26, 2007 | 07:04 PM
vetset63's Avatar
vetset63
thanks ive used a impact but my compressor gives out before the bolt.
ive been reading threads and got some ideas.
Old Jan 27, 2007 | 01:14 AM
2001TEGGSR's Avatar
2001TEGGSR
You can use a breaker bar, positioned against the ground and tap the starter. Just be careful, double check its not going to fly into your radiator.
Old Jan 27, 2007 | 09:02 AM
bob01721's Avatar
bob01721
There's a special tool to hold the pulley in place while you break the bolt loose. If you're in the South Jersey/Philly area, I'd be happy to loan you mine.
Old Jan 27, 2007 | 09:03 AM
bob01721's Avatar
bob01721
Oops! Posted it twice. Disregard this.
Old Jan 27, 2007 | 05:55 PM
vetset63's Avatar
vetset63
thank you but im in ky. and i got it off with a 4' bar and a lot of ass. thanks for all the help.
