Noob Question
Old Jan 17, 2007 | 09:17 PM
uo959's Avatar
uo959
Default Noob Question
Hey guys, I have a question on big time WHP.
I have a 99 Civic EX Coupe. I was planning on getting either a b18c1 or c5 swap in it. I was told get the c1 if your going to turbo because of compression. So how does everybody get the 350+ whp?? What all do you do and where do you get it??
Thanks
Old Jan 18, 2007 | 08:59 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
If you are shooting for 350 whp, you will have to strengthen the bottom end so it doesn't matter if you buy the C1 or C5. After rebuilding the bottom end, they both turn out identically, minus the head.
All you need for 350 whp is a medium sized turbo, forged pistons and rods, and a good tune.
Old Jan 18, 2007 | 10:39 AM
Snoopy's Avatar
Snoopy
been there done that
dont forget fuel system
Old Jan 18, 2007 | 10:54 AM
Provocateur
On permanent hiatus
Good call. I guess I just factored that into the turbo setup. h:
Old Jan 19, 2007 | 08:19 AM
uo959's Avatar
uo959
So if I wanted more, I would get a bigger turbo??
What do you mean strengthen the bottom end??
By fuel system do you mean just injectors and fuel rail??
Old Jan 19, 2007 | 09:06 AM
Provocateur
On permanent hiatus
Or up the boost on the current turbo depending on its efficiency and ability to perform at a higher boost level.
Forged rods and pistons and possible sleeves depending on power goals.
Higher volume fuel pump, larger injectors, and fuel pressure regulator. The stock fuel rail is capable of holding well over 500 whp, so it isn't necessary to upgrade.
Old Jan 22, 2007 | 12:47 PM
mberndt's Avatar
mberndt
No offense, but you should really read up on what we mean by building/strengthening the bottom end... Not to mention how turbochargers work...
It's not that easy to slap a turbo onto a B18C1 and get 350whp...
I wish
