Engine head difference?
Old Jan 2, 2007 | 06:46 AM
ivan323's Avatar
ivan323
Default Engine head difference?
Guys, is there any difference in engine head for B16A & B18C, i hope to know abt the physically difference like height?
Lets exclude the valves, TB n intake manifold, etc.........
How r we able to verify w/o much trouble?
Old Jan 2, 2007 | 11:01 AM
Snoopy's Avatar
Snoopy
been there done that
which b18c are you referring to? there's the itr b18c and gsr b18c. the itr b18c and b16 do share the same pr3 casting. the gsr b18c has a p72 casting.
differences include different bolt patterns on the intake side, pr3's have a bigger combustion chamber, different valve angles. they're both the same physical size.
they're stamped either pr3 or p72 right above the exhaust ports
Old Jan 4, 2007 | 04:22 AM
ivan323's Avatar
ivan323
I'm talking abt the JDM B18c, i thought the difference for B18C n B16A height is 2mm?
Pls correct me if i'm wrong..
Thanks..
Old Jan 4, 2007 | 10:31 AM
Snoopy's Avatar
Snoopy
the b16a block is shorter than b18 blocks, not the head
Old Jan 5, 2007 | 02:42 AM
ivan323's Avatar
ivan323
So all the head is the same size?
Old Jan 5, 2007 | 11:54 AM
Snoopy's Avatar
Snoopy
yes
Old Jan 6, 2007 | 06:29 AM
ivan323's Avatar
ivan323
yes
Thanks alot for ur great info again..
