Which Turbo For My Setup?
Old Dec 11, 2006 | 11:47 PM
aboobybobpleez's Avatar
aboobybobpleez
Certified Rice-Rocket
Default Which Turbo For My Setup?
Wondering which turbo to use for my setup..i have a t25 60trim but has a bit of shaft play and im still not sure if i want to use this trim on this setup. i want to know what i can run on 440 injectors. Its going into a 99 si
my setup is:
ls block:
9.0:1 81mm forged rods
b16 head:
itr cams
obx valves
skunk2 springs/retainers
itr manifold
rpm service 70mm tb
bored fuel rail
rc 440cc injectors
turbo setup:
drag log manifold
turbonetics 38mm wg 8psi spring
fmic
im using hondata s200
Old Dec 12, 2006 | 07:22 AM
Snoopy's Avatar
Snoopy
been there done that
how much power do you want to make? with those injectors you shouldnt go over 300whp. upgrade to bigger injectors and you can make more power.
Old Dec 12, 2006 | 10:24 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
I agree with Snoopy. Those injectors may be able to squeeze 350 whp with a FPR and a high static fuel pressure, but why bother? I would get 750's just to allow more room if you want to up the power.
What is your budget for a turbo? What flange does that manifold utilize?
Old Dec 12, 2006 | 06:26 PM
aboobybobpleez
i dont know if this is a good trubo or no to use or not and i dont know what model....the specs are: garrett bcc A/R 60...i just found out that it is t3 flanged
