Daughter totaled her Civic, need swap
Old Nov 15, 2006 | 03:43 PM
Rebelwork's Avatar
Rebelwork
senile
Default Daughter totaled her Civic, need swap
Daughter took on a dual wheel 1ton truck, lost and now Im buying a replacement car.
Daughters car is a 1993 DX and have found a 95 EX(blown motor). I need to replace the EX D16Z6 motor&tranny with the DX D15B7 motor&tranny to get the 95 road worthy.
Other than motor, tranny transfer, what else will I need to do. Was looking into a new leather interior for her car for christmas. But this changed the order of uprades ....thx Jack
File Type: jpg
File Type: jpg
Old Nov 17, 2006 | 04:39 PM
Rebelwork's Avatar
Rebelwork
senile
I assume this is a simple,typical swap with ECU swap as well. Just looking for a lil reassurance. Anyone?.
Sorry for the basic question but as I was going one step forward with the 93 DX , the crash forced me back 3 steps...Jack
Old Nov 17, 2006 | 08:33 PM
project_hatch's Avatar
project_hatch
Power by Uncle Ben's Rice
I beleive only difference in the 2 is the head...one is y7 and the other is y8 not sure...but they are completly interchangable for those years, everything will interchange perfectly on those 2 cars, take a weekend, some corona, a cherry picker and some purple gloves and get started.
Old Nov 21, 2006 | 12:04 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
What the hell are you talking about....?
No worries. If the tranny in the EX is still good, it will have slightly shorter gears. Although, it may not be a good idea with your daughter.
Aside from that, you can keep the axles where they are, in the respective cars, same with shift linkage. Just need to pull the engine and tranny, then swap the ecu.
The only other issue you'll run into is the map sensor. The DX has the map sensor on the firewall. The EX has it on the throttlebody. So.... You can keep the ex throttlebody with the car, along with the engine wiring harness, and the rest of the d15b7 stuff will bolt up.
Option be would be to keep the engine harness with the car and mount the map sensor on the firewall form the dx. You'll just have to run the vaccum line.
Now the reason you're keeping the engine harness with the car is that on the EX the engine harness has the map sensor connection. On the dx, the map sensor connection is part of the chassis harness.
The only other difference in the harnesses is that the ex will obviously have the two plugs for vtec, while the dx will not. So, you'll have two extra plugs on the engine harness when all is said and done.
Cliff's notes: keep axles (with abs rings that the dx axles don't have), throttle body and engine harness with car. Swap in engine. Use the mounts on the engine already. Swap ecu. Done.
Old Nov 21, 2006 | 07:05 PM
Rebelwork's Avatar
Rebelwork
senile
'Thanks for the info. Most everything has been disconnected so far, but found the passenger side strut is jambed upward from the impact. Trying to salvage the DX axles,etc. No point giving them to the salvage yard.
Tell you what...I dont know how much room is available on the manual transmission but there ain't squat pulling the motor-auto tranny as a whole ....Jack
