Rough starting b18c1
Old Oct 29, 2006 | 03:47 PM
95LSv's Avatar
95LSv
Banded
Default Rough starting b18c1
My 94 gsr motor starts up really hard. When I turn the key it sort of sputters, and if a press the gas when its still cold, the motor sounds like its chocking. After about <5 mins of idling, when it warms up, the problem goes away. Is this something to worry about??
Old Oct 29, 2006 | 05:03 PM
Fuse's Avatar
Fuse
bad coolant censer or maybe a misfire (bad plugs) do you smell a lot of gas
Old Oct 29, 2006 | 11:12 PM
95LSv's Avatar
95LSv
Banded
Bad coolant sensor, lol its funny you say that because I've been getting a code 6, Engnie coolant Temperature sensor, and i've been trying to fix it. Plugs are new, so are the wires. The head has pretty much 0 miles on it. So i'll check that ect sensor... Thanx
Old Oct 30, 2006 | 04:18 PM
Fuse's Avatar
Fuse
fix the code 6 i think(i don't work for acura)the coolant censer is just a 2 wire on is the 12v to the censer and the other is signal wire so see if you have 12volts to one.to check the signal wire you have to do a continuity test from the terminal at the censer and the terminal to the computer unplug the computer first.so if you have 12v and good continuity it ether the censer or the computer replace the censer first.am i spelling censer rite it doesn't look rite.
Old Nov 4, 2006 | 10:51 PM
R_Squared's Avatar
R_Squared
LEVEL UP
I will have to try this as well. I'm throwing a CEL code 6 for the ECT sensor as well, and my car has been running kinda crappy. Oh, and it's spelled sensor. h:
Old Nov 4, 2006 | 10:53 PM
R_Squared's Avatar
R_Squared
LEVEL UP
anybody know the part # or have a pic of the ECT sensor? I know there are a couple different coolant sensors, so I want to make sure I order the right one.
Old Nov 5, 2006 | 12:03 PM
Fuse's Avatar
Fuse
thanks as everyone know i can not spell but i am getting better.
Old Nov 5, 2006 | 04:00 PM
95LSv's Avatar
95LSv
Banded
So far I've replaced the sensor twice with good ones, and pinned it to the ecu, bypassing the harness just in case there was a short along somewhere and still the code remains. (I did reset the ecu, after, and still the code is there), someone plz help, this stupind car is driving me out of my mind...
