Car doesn't want to start... Help!
Old Oct 22, 2006 | 04:40 AM
hawj920's Avatar
hawj920
Default Car doesn't want to start... Help!
I have a LS swap 94 civic. My car will not turn over, it will crank but not turn over at all. I had a complete MSD setup on the car that I uninstall to find out what the problem was. I replace the distributor and still nothing. I checked for spark and there was no spark, even after I replace the distributor!!!
Another thing is that I don't think I am geting any gas either because I don't smell anything and most people said that if they don't get any spark they would smell gas not being burn... No gas no spark... Help! I will replace the ECU and fuse today... My fuel pump is less than a month old. Can it be faulty wires??? More fuses?
What can I do next??? All help and advices would be greatly appreciated...
Old Oct 22, 2006 | 08:44 AM
Fuse's Avatar
Fuse
o first lest see if the pump is turning on when you first turn on the key(not the start position the on position) you get a 2 second fuel pump turn on this helps to build fuel psi be for start up so have a Friend turn on the key and you listen for the fuel pump to turn on. lets start there. then we will deal with spark.
