Problem When V-tec Engages
Old Oct 6, 2006 | 11:46 AM
Nokturnal82's Avatar
Nokturnal82
it's all about the launch
Default Problem When V-tec Engages
i've been rebuilding my '97 gsr(from a wreck) and ran into a new problem. i've just about got everything back together and running well...until now. Here's the problem: When v-tec engages (around 57-5900, I'm assuming a little late, b/c it's stock and hasn't ever been tuned...150k miles) the tach needle jumps from 6 to 7000 and kind of bounces around. At the same time the needle jumps the check engine light, on the dash, start surging/flashing. The only reason the CEL is on is, b/c the o2 sensors are not installed. Important fact: the car still pulls hard throughout the entire powerband, so I'm assuming v-tec is still working. The car has been running well for a couple of months, since i put it back together. this just came out of the blue. Any thoughts? Thanks.....
Old Oct 7, 2006 | 07:28 PM
2001TEGGSR's Avatar
2001TEGGSR
I'd get the o2 sensor(s) installed soon. You're probably running very rich without them. As for the tach, did you try the general tune-up stuff? Plugs, Dist. Cap, Rotor, etc.?
If the car seems to run ok, it might just be a wire/ground issue with the tachometer. I'm not sure how to check it with a volt meter. Mabye somebody else could suggest that?
Old Oct 10, 2006 | 11:50 AM
Nokturnal82
Yes, the car still runs well. i'm going to check the tach ground and other wires, b/c this problem didn't happen the last 2 days. thank you for your input.
Old Oct 16, 2006 | 11:38 AM
mberndt's Avatar
mberndt
Look up my post on my Tach jumping issue... It was a lose ground wire, could be your problem too!
Good luck...
