Timing belt
Old Aug 30, 2006 | 07:05 AM
Maverick-GSR's Avatar
Maverick-GSR
Default Timing belt
If the timing belt skips a tooth on the gears, but doesn't break, is it enough to damage any valves?
Old Aug 30, 2006 | 11:03 AM
shivers's Avatar
shivers
Moderator Alumni
The answer is ... maybe. Depending on where in the stroke the belt slipped, you could have had some valve to valve contact. Even just a small nick is enough to cause issues. Have a leak down test done to see if all the valves are sealing properly. Good luck.
2005 s2000
Old Aug 30, 2006 | 02:21 PM
spoon-eg-'s Avatar
spoon-eg-
fix the timing and get a new belt is what i would to homefully you didnt drop a vavle my friends motor did this and the shit was gone to hell
Old Aug 31, 2006 | 04:04 PM
Maverick-GSR
Thanks for you help, I swapped the belt, tensioner, and water pump and she's running great again, lucky for me it only jumped when i was stopped at a light at idle
Old Aug 31, 2006 | 04:07 PM
spoon-eg-'s Avatar
spoon-eg-
man your the luckiest person in the world!!
