Integra Engine swap! Pls Help!
Old Aug 10, 2006 | 03:19 AM
krypton's Avatar
krypton
Default Integra Engine swap! Pls Help!
I have a 1994 honda integra Zx 1.6 Dual Carb, the engine is blown and i need to swap it. Would a 1.6 DOHC Vtec engine be an easy swap? or would it require alot of modifications...
Also what about a 1.8 Vtec engine from a 1995 Integra? Would that be an easy swap or would it require many modifications.
Thanks
Old Aug 29, 2006 | 06:01 AM
primetime's Avatar
primetime
I think all integra's 94 and up are 1.8 liter. but to answer your question, the 1.8 Vtec motor will drop in with no modifications needed! just make sure that you get the engine wiring harness and the ECU!! The block code on the 1995 gsr (vtec) motor is B18C1 and The Code On the Head is P72.
Old Aug 29, 2006 | 07:28 AM
KungFuKorean's Avatar
KungFuKorean
I have a friend with a 94 teggy with an LS/VTEC swap and it's very fast!! but if you have the money, the B18C is the way to go... I have also heard of an H22A swap for this year, but it requires a lot of work...
Old Aug 30, 2006 | 12:05 PM
BtTurboM3's Avatar
BtTurboM3
your car has a 1.8 liter stock unless you bought it with the 1.6. i would go for the B18C1 (Gsr as you all know) get the engine you were talking about the "1.8 Vtec engine from a 1995 Integra" that will fit and it will be faster then your other one. it will install easy sence it was built to be in your car. good luck...
Old Sep 1, 2006 | 12:15 PM
Snoopy's Avatar
Snoopy
been there done that
the guy is obviously not from the states. not all integra's in other countries had b series in them.
bballin24rican
CRX & Pre 92 Civic
2
May 17, 2007 07:05 PM
twisted91588
5
Dec 9, 2004 04:00 PM
lrcs
Accord
6
Feb 10, 2004 06:14 AM
jgusa
Engine Swaps, Tech & Tuning
Apr 7, 2003 08:32 PM
Mason007
Nov 12, 2002 07:02 PM
