00ek wiring jdmb8ci
Old Jul 7, 2006 | 09:46 AM
MuGeN_Ek/coupe's Avatar
MuGeN_Ek/coupe
Default 00ek wiring jdmb8ci
Im doing a 97 jdm b18c obd2b into a oo ek coupe dx. The motor is in, pretty much all the mechanic part iz done. But 1 problem the wiring part. When I purchase my motor the guy said I could use my stck harness for my jdmb series. N my friend whose helpn me wit it said to order a intgra harness, so i did, frm the same yr as my jdmb. Now neither one of them fits. So my questn is what kind of harness would i need, would an Si 00 work. Need your knowledge plllllllllllsssssssssss......
Old Jul 7, 2006 | 10:32 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
you can use a What year of integra harness? Gsr, ls? A 99-00 civic si harness would work. What ecu are you going to use?
Old Jul 7, 2006 | 11:43 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
it would be best to use your dx harness and add the wires that you need. that or shell out and buy an ex,hx,or si harness that alreay have the wires needed for vtec
you cant use the integra harness for anything other that spare wires. Integras use a 2 piece harness.
Old Jul 7, 2006 | 12:13 PM
MuGeN_Ek/coupe
Im usin my gsR ecu.N i dont wanna use my Dx harness becuse dnt wana splys them. My friend did that he ran into alot of problem down the road. Im lookin for a less hassle. PLUG N PLAY
Old Jul 7, 2006 | 12:15 PM
MuGeN_Ek/coupe
Im usin my gsR ecu.N i dont wanna use my Dx harness becuse dnt wana splys them. My friend did that he ran into alot of problem down the road. Im lookin for a less hassle. PLUG N PLAY is what im lookin 4, a little bit of work but not too much. More drivein less splysn. So whats my best bet....???
Old Jul 19, 2006 | 11:05 PM
MuGeN_Ek/coupe
ok! I used 00 si harness, it all seems to fit. But Im pluged wit my (obd2b) dx 00 ecu. So I turn the key n the motor started but it died. Evry tym I do it same thing happends. Why iz it doing tht? iz it b cause the ecu iz dx n not the right one (I have a jdmb18c obd2a in my 00 dx coupe). Any ideas or suggestions......
Old Jul 27, 2006 | 09:00 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
ummm.... youre trying to use a dx ecu after you swapped the motor?
Old Jul 30, 2006 | 03:15 PM
MuGeN_Ek/coupe
No Im using my gsr ecu. I finally got it runin but the check engine light comes on. jst when i pull it hard around 5 n half to six rpms. n lately when come to a stp the car dies. its idleing very low. but the engine check light goes away after i turn the car off. So wat u think?
Old Aug 7, 2006 | 06:04 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
could be a few things. you should check the code and see what the ecu is saying t is. could be knocking?
Old Aug 9, 2006 | 08:25 PM
96scgsrcoupe's Avatar
96scgsrcoupe
If you are using an 0bd2a ecu in your 00 coupe then you will run into problems. You need an ecu from an si or 98-01 gsr/type r.
