b20 vtec Catch Can
Old Jun 14, 2006 | 04:00 PM
Jerod's Avatar
Jerod
sick of it
Default b20 vtec Catch Can
I have a fully built b20z w/ a gsr, head all moter setup (11.8:1 comp). When i put the motor in there was no place to bolt the black box for the pcv valve up to, so i did not put it on. So as of right now i am running with no pcv valve. I have a catch can and have no idea where to hook the hoses up to. Can someone help me with these problems. i posted on another forum and the people had no idea.
Old Mar 19, 2008 | 08:47 AM
95_civic_lx's Avatar
95_civic_lx
i thought if u knew how to swap an engine u would know how to put in a pcv system...
im running turbo so its a lil different but the way it works its the same....in the back of the block there is a crank vent (usually a black box) the house goes from there to the intake mani since it has vac. u said there was no place...u can put a hose fitting dirrctly into your block or get the right black box. i would put something...u dont want random crap getting in there. just put that hose and the once from your vac together into the catch can then into the IM. if u want to keep the pcv valve just put ur can after the pcv and before your IM
Old Mar 19, 2008 | 09:10 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
What kind of catch can are you using?
If it is an open breather can, you need to run fittings off the back of the block for adequate ventilation. If it is a sealed can like Greddy, hook one hose to anywhere that crank pressure is present and the other hose to a manifold vacuum source.
Old Apr 6, 2008 | 03:41 AM
Jerod's Avatar
Jerod
sick of it
good timing i sold the car like a year ago
