Need help with 99 civic ECU
Old May 27, 2006 | 07:15 PM
zerojames's Avatar
zerojames
Default Need help with 99 civic ECU
I have a 99 civic hb and a buddy if mine told me if i got a 97 sohc motor w/ harness and ecu it all should plug and work since previous owner cut all the plugs off the old harness. All the plugs plug into the ecu except the one not from the harness. Can I go to the junk and get that plug and rewire it or am I in a pit too deep to get out since I need it running by this weekend.
Old May 27, 2006 | 10:29 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I don't see why it wouldn't work. They are both OBD2a, so the harnesses should be identical.
Old May 29, 2006 | 05:26 AM
schmi220's Avatar
schmi220
Large Member
'99 is obd2b. The plugs will be different.
Old May 29, 2006 | 10:56 AM
zerojames's Avatar
zerojames
so the plugs are different. In that case can I rewire it to work with the right plug?
Old May 29, 2006 | 11:12 AM
Provocateur
On permanent hiatus
Yeah, you're right. Civics changed over to OBD2b in 99 and Integras changed over in 2000.
You can buy a conversion harness that will convert your OBD2b plugs into OBD2a plugs.
Old May 29, 2006 | 02:53 PM
2001TEGGSR's Avatar
2001TEGGSR
http://ecu.ff-squad.com/jumper.obd2b.htm - They have ECU Conversion Harness very reasonable...
Old May 29, 2006 | 03:00 PM
zerojames's Avatar
zerojames
Thanks for the info. The problem I have is that I have a complete 97 sohc motor with ecu and engine harness and I was told it would fit and plug up and start in my 99 ek. I got the harness because old one was missing some plugs and ecu plugs were all cut up. The main question I have is can i go to a junk yard, buy the fourth harness plug, and rewire it to work in my 99 ek. I believe the fourth plug is the one from the dash(the plug that is not attached to the engine harness) Oh and my axles are from a 93 civic, they should fit into my ek too right?
Old May 29, 2006 | 03:06 PM
2001TEGGSR's Avatar
2001TEGGSR
So all the plugs fit in the ECU, but your missing one? If this is the case, you could do as you stated and re-wire with the missing plug obtained from a junkyard. Im not sure about the axels, do a search...
