what injectors should i use??
Old Apr 20, 2006 | 05:00 PM
madman4you's Avatar
madman4you
Default what spark plugs should i use??
ok so if you dont know im doing my stock b16 turbo project. just want to know what the best spark plugs i should buy? and if i need to change my spark plug wires right now?? if soo what should i get??
Old Apr 20, 2006 | 06:04 PM
Sirfallsalot243's Avatar
Sirfallsalot243
What are you asking about? Injectors or spark plugs?
Old Apr 21, 2006 | 04:36 AM
EX plicit's Avatar
EX plicit
OH SNAP!
NGK or NGK V-power plugs will be fine. Fresh wires wouldn't hurt either.
Old Apr 22, 2006 | 05:23 PM
madman4you's Avatar
madman4you
i need to know about heat rage in the spark plugs i think stock ones are 6
Old Apr 22, 2006 | 08:28 PM
dubcac's Avatar
dubcac
I
NGK copper, I'd run a 7 or 8 heat range. You need to run colder than stock. Look for a BKR7E plug...thats what most people run under boost. You're also going to need to run a shorter gap.
Old Apr 22, 2006 | 09:18 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Yep. I am running the BKR7E gapped to .030". Typically, you want to keep the gap as wide as you can without misfiring. This will put less strain on the ignitor.
Old Apr 24, 2006 | 06:21 AM
EX plicit's Avatar
EX plicit
OH SNAP!
Also keep in mind when dealing with NGK plugs, the higher the number the colder the plug. I've ordered 1 step colder plugs for my turbo b16 project which ended up being a 7.
Old Apr 24, 2006 | 07:21 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You get a hotter spark with a larger gap as well.
Old Apr 24, 2006 | 06:42 PM
madman4you's Avatar
madman4you
schmoo are these the ones that would work for my car?
http://cgi.ebay.ca/ws/eBayISAPI.dll?...DME:L:RTQ:CA:1
Old Apr 24, 2006 | 07:44 PM
Provocateur
On permanent hiatus
That looks like them.
