oil feed for turbo???
Old Apr 16, 2006 | 05:57 PM
madman4you's Avatar
madman4you
Default oil feed for turbo???
just wondering where the best spot to get the oil feed for the turbo would be??
Old Apr 16, 2006 | 06:49 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Just get an oil line kit that includes both the return line/fittings and the feed line/fittings.
If you know what fittings you need, atpturbo.com is a great place to get them.
If you don't know what fittings you need and just want a kit, tunertoys.com is a great place to get them.
Old Apr 17, 2006 | 12:58 PM
madman4you's Avatar
madman4you
sorry, i mean like where do i tap into to allow oil to run through the engine and through the turbo??
Old Apr 17, 2006 | 02:31 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Back of the motor, just to the left of the oil filter is the stock oil sending unit that's threaded into the motor. Just unscrew it, run a line from that hole to your firewall and 'T' it off there to run your OEM sending unit and your feed line to your turbo. Simple.
Old Apr 17, 2006 | 03:53 PM
Provocateur
On permanent hiatus
Originally Posted by westcoaststyle
Back of the motor, just above and to the left of the oil filter is the stock oil sending unit that's threaded into the motor. Just unscrew it, run a line from that hole to your firewall and 'T' it off there to run your OEM sending unit and your feed line to your turbo. Simple.
Or a sandwich adapter like Greddy or Golden Eagle.
Old Apr 17, 2006 | 05:14 PM
madman4you's Avatar
madman4you
nice you two guys are the best guys to get info of off, so i never usually need to search else where after asking you two. thanks again Schmoo, and Westcoaststyle
Old Apr 17, 2006 | 05:49 PM
westcoaststyle
np mang
