Block guard/ sleeve saver
Old Mar 17, 2006 | 09:08 PM
95LSv's Avatar
95LSv
Banded
Default Block guard/ sleeve saver
Can anyone tell me what the point of a block guard is, and how it works? Do I need one? Im dropping in a jdm b16 sir2 short block with 99 b16 head into my integar... pushing around 11 to 1 compression...
Old Mar 18, 2006 | 10:44 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
You don't need one.
Old Mar 18, 2006 | 11:30 AM
95LSv's Avatar
95LSv
Banded
lol... so then what the heck is the purpose of it??
Old Mar 18, 2006 | 01:49 PM
Provocateur
On permanent hiatus
It prevents the upper sleeves from flexing. Usually, they are only used in boosted applications to prevent cracked sleeves. More than likely, if a sleeve cracks, it is a tuning problem and a block guard won't do shit to prevent that.
Old Mar 18, 2006 | 01:50 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
It's made to be a poor-man's solution to sleeving a motor. AEBS, Benson, and a few other companies make full sleeves that replace the stock sleeves. They include a closed-deck design (to a degree) that anchors the tops of the cylinders by closing off the space between the tops of the cylinders and the block where the water jackets are. This eliminates potential dangers that a motor making a good deal of HP might face. The block guard simply is the top portion of these sleeves, but is not in any way as good as a replacement sleeve with the built-in block guard. Many people actually ruin engines by attempting to install them. If you're serious about making power and think you need a block guard, get new sleeves installed. You will be much happier with the result.
