B18C5 swap into 95SE
Old Mar 12, 2006 | 10:37 AM
emspilot's Avatar
emspilot
Default B18C5 swap into 95SE
This may have been covered before, but will a Type R B18C5 engine drop into a 95SE (5 spd) without any mods/changes? Just bolt in swap?
Old Mar 12, 2006 | 11:28 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
It will physically bolt in, but you'll need to wire up the VTEC solenoid and knock sensor. Also you'll obviously need to run a GSR or ITR ECU.
Moved to Hybrid Forum.
Old Mar 12, 2006 | 10:00 PM
To add to daves post, a OBD converion will be needed...
Old Mar 14, 2006 | 06:31 AM
emspilot's Avatar
emspilot
Got it guys...
Thanks.
Old Mar 14, 2006 | 09:18 AM
sherwood's Avatar
sherwood
I missed Sean
the type-r is also overrated. the engine is not owrth the extra money... spend it on an ls with boost or a gsr with some mods or boost instead
Old Mar 14, 2006 | 11:56 AM
emspilot's Avatar
emspilot
That's kind of what I was thinking. I have a 95 SE that's in great shape. I'd like to put a VTEC engine in it, so I'm leaning towards the GSR engine.
