Throttle Body help
Old Mar 3, 2006 | 10:10 PM
95LSv's Avatar
95LSv
Banded
Default Throttle Body help
With a throttle body like this one, where are you supposed to connect the vacuum lines to??? because the stock ones have, i think, 2 vacuum lines connected to the throttle body...
Disregard the Manifold Pic
Old Mar 4, 2006 | 12:20 PM
95LSv's Avatar
95LSv
Banded
Anyone?
Old Mar 4, 2006 | 12:46 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You have to bypass the throttle body when hooking up the coolant lines.
Why do you need a bigger throttle body? What are your other mods?
Old Mar 4, 2006 | 01:18 PM
95LSv's Avatar
95LSv
Banded
I was actually looking at a PRELUDE 68mm TB... Does that fit?
Other mods are type r pistons, jdm gsr internals, si ported head, si ported IM, and i might get upgraded cams.
Old Mar 4, 2006 | 05:25 PM
Provocateur
On permanent hiatus
You will want to do the cams before you deal with a bigger throttle body. I am running the stock body on my setup and it does just fine, so I think you can wait on that for a while.
