VTEC Cams.
Old Feb 19, 2006 | 05:46 AM
psx_pat's Avatar
psx_pat
Default VTEC Cams.
Is it true usually stage 1 and stage 2 cams, the difference compare to stock cams is only on VTEC cams? I mean for B16A or B18C cams.
Old Feb 22, 2006 | 04:17 PM
AcuraFanatic's Avatar
AcuraFanatic
Um, what?
Old Feb 23, 2006 | 06:30 AM
psx_pat's Avatar
psx_pat
I meant compare to stock cams, usually stage 1 or stage 2 cams have the same primary cams (low cams) and the secondary cams (VTEC cams) are different form stock. Is that correct?
Old Feb 24, 2006 | 10:52 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
No, they are different. If they were the same, why is the idle typically lopey on Stage 2 cams?
You can buy Crower cams with aggressive vtec and stock idle lobes, however.
Old Feb 25, 2006 | 01:16 AM
psx_pat's Avatar
psx_pat
How about stage 1 cams. Is the primary the same?
