Stage 1 cams.
Old Feb 14, 2006 | 07:26 PM
psx_pat's Avatar
psx_pat
Default Stage 1 cams.
I just bought Crower stage 1 cams for my B16A 1st gen engine. After I installed it, do it to adjust the valve clearance according to stock B16A (Intake : 0.15 - 0.19 ; Exhaust : 0.17 - 0.21)? Or there are require different valve clearance? Also usually which one is better when setting the valve clearance, going for bigger number or smaller number? Thanks.
Old Feb 16, 2006 | 06:40 PM
psx_pat's Avatar
psx_pat
Help,anyone?....
Also do you think I need cam gears for these stage 1 cams? (I won't go bigger than stage 1 in the future).
Old Feb 16, 2006 | 06:54 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The valve lash should remain the same regardless of what cams you put in there.
If you want to extract as much power out of the car and you plan on dyno tuning it, a cam gear set would be something good to have.
Old Feb 17, 2006 | 06:07 AM
psx_pat's Avatar
psx_pat
Thanks. Could anyone explain to me what this site talk about
http://www.crower.com/misc/valve_timing_chart.html
What does it mean by lobe center?
I bought crower stage 1,so which one I should use the information on this site. Thanks.
Old Feb 17, 2006 | 06:11 AM
psx_pat's Avatar
psx_pat
Just as info. Crower stage 1 cams, intake : lift 11.38 duration 249@1mm ; exhaust : lift 10.54 duration 240@1mm.
