Please help with swap, evap.
Old Jan 23, 2006 | 06:09 AM
JasonST's Avatar
JasonST
Default Please help with swap, evap.
Hey so I'm workin on my h22 swap into my teg and ran into a problem. I don't have the evap sensor or a the right evap canister to work for this. So I was wondering, can I just take it all off and not use the evap? I don't have to worry about emissions where I live but will it hurt the engine at all? Thanks for any help in advance! o and by the way the ecu is a p13 92-95 so will I get a CEL?
Old Jan 23, 2006 | 06:17 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
I would run the evap, or you may run into some problems down the road.
Old Jan 23, 2006 | 02:13 PM
JasonST's Avatar
JasonST
Default What sort of problems?
What problems would I run into? I would run it except I don't have the right Evap can. mines from a teg and only has 2 vacuum lines on it instead of 3, and I'm trying to use the evap sensor off my b18b1. O and I dont have an Evap 2 way valve. Evap wasn't hooked up on my obd1 b18b, what problems will I run into? Thanks for any help in advance .
