fuel injectors
Old Jan 12, 2006 | 11:12 PM
colby233's Avatar
colby233
Default fuel injectors
Was wondering how different obd1 injectors are compared to obd2? How complicated would it be to put obd1 injectors in an obd2 integra?
Old Jan 13, 2006 | 09:29 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
The clips are totally different. To put OBD1 injectors in an OBD2 car, you will need to cut off the current wiring harness and splice an OBD1 one in. All aftermarket injectors use the OBD1 harness.
Old Jan 13, 2006 | 11:35 PM
colby233's Avatar
colby233
Thanks alot for the information.
Old Jan 16, 2006 | 09:52 AM
stemyluv69's Avatar
stemyluv69
I thought RC injectors were available in obd1/2, and available in peak and hold as well as saturated. How are DSM injectors installed in a 97 gsr.... not that i would need them or anything
Any writeups on it? I haevnt found any. I know dsm's need a resistor box, but hows that hook up etc. holla!
Old Jan 16, 2006 | 04:28 PM
Provocateur
On permanent hiatus
All aftermarket injectors come with OBD1 clips. You have to have an OBD1 harness to run them. For DSM injectors on a high impedence system, you will need to wire in a resistor box or a set of inline resistors because they are low impedence. If you need some instructions, PM me and I will send you the link when I get home.
