Wiring question?
Old Dec 11, 2005 | 01:43 PM
Gen2teg13's Avatar
Gen2teg13
Default Wiring question?
I wanted to know if someone could tell me what wires are the cylinder sensor wires on a OBD-1 distributor?
What my problem is that I'm in limp mode and my ecu is throwing a cylinder sensor code. I converted my 91 integra over to obd-1 using a gsr distributor and a gsr ecu and the proper conversion harnesses. I tried swapping another obd-1 distributor that I knew worked and ran into the same problem. So now i'm trying to get out of limp mode and one suggestion was that to take the cylinder sensor wires from the distributor and take them straight to the ecu.
So what I'm planning on doing is taking the cylinder sensor wires from the C1 (Blu-Grn) and C2 (Blu-yel) on the obd-0 ecu harness straight to the wires on the distributor.
Any help would be appreciated or other suggestions to go about this problem.
Old Dec 15, 2005 | 08:38 PM
cartuner's Avatar
cartuner
Try this diagram.
File Type: pdf
Old Dec 18, 2005 | 01:04 PM
Gen2teg13's Avatar
Gen2teg13
Thanks for the diagram it helped me out a lot. I really do appreciate it.
