turbo si problem w/greddy fcu any help please
Old Dec 5, 2005 | 04:03 PM
1bustedSi's Avatar
1bustedSi
Default turbo si problem w/greddy fcu any help please
the car won't start does anyone have any solutions to this i am totally and utterly lost should i try another method without the fcu the car won't idle is there a way to get around this any help would be greatly appreciated
Old Dec 5, 2005 | 11:30 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
What do you mean "the car won't start"? You need to double check the wiring for the blue box and make sure it is correct.
If your idle is poor, first make sure the light on the box is correctly lighting up and second, double check that MAP sensor wire you had to cut to hook it up. There is most likely a loose connection causing MAP sensor failure. Are you throwing any codes?
Old Dec 6, 2005 | 05:59 PM
1bustedSi's Avatar
1bustedSi
after hooking the fmu up the car would not, but greddy emailed me the wiring instructions and I figured it out it was a stupid mistake I had wired the injectors backwards
