injector?
Old Nov 5, 2005 | 03:23 PM
gsrsol's Avatar
gsrsol
slow and low
Default injector?
i was wondering if anyone knows how many cc's the injectors off of a gsr, an itr, a h22 and a h23 are all from obd1 years. any info would help
Old Nov 5, 2005 | 08:37 PM
dubcac's Avatar
dubcac
I
All obd 1/2 B series are 240cc's saturated
All obd 1/2 D series are 240cc's saturated
1992-96 Prelude non-vtec (h23) Peak and hold 240cc
1992-96 Prelude VTEC (h22) Peak and hold 345cc
1997-up Prelude VTEC (h22 obd2) Saturated 280cc
Old Nov 6, 2005 | 10:03 PM
gsrsol's Avatar
gsrsol
slow and low
thank you very much dubcac
Old Nov 7, 2005 | 04:56 AM
psx_pat's Avatar
psx_pat
Does JDM B16A 1st generation same type and size as B20B (97/98 CR-V)? Thanks.
Old Nov 7, 2005 | 08:29 PM
dubcac's Avatar
dubcac
I
They are different obd versions, however the flowrate and type is the same.
Old Nov 8, 2005 | 08:22 AM
psx_pat's Avatar
psx_pat
Thanks. Just some more questions, does pulse is also the same (I know the ECU control the pulse). I meant I have B16a head with B20B block.I know B20B needs more fuel,so if I set the fuel pressure regulator the same as stock B20B engine is it okay (around 38-45psi with vaccum off)? Also,the fuel pump rate is the same between B16A1 comapre to B20B? Thanks.
Old Nov 8, 2005 | 02:10 PM
dubcac's Avatar
dubcac
I
The fuel pump rate is determined by the pump in the car, not the motor. As for the FPR, you may want to bump it up a few PSI at idle, but I'd get a VAFC and have the fuel adjusted on a dyno to be safe.
Old Nov 8, 2005 | 04:49 PM
gsrsol's Avatar
gsrsol
slow and low
whats the difference between saturated and peak and hold.
Old Nov 8, 2005 | 06:15 PM
b16ahybrid's Avatar
b16ahybrid
Saturated = high impedence
peak hold = low impedence
resistance
