honda injectors ratings
Old Oct 29, 2005 | 11:18 AM
Sharpe's Avatar
Sharpe
Default honda injectors ratings
im looking to put a turbo in my 91 ls someday and im gonna try to it myself by getting all of the parts i can out of the junk yard. my question is what are the ratings on some honda injectors. i was gonna go with the dsm 450 cc's but if i can find some good ones from honda (350 - 450)i would rather use them so i can represent.
Old Oct 29, 2005 | 01:35 PM
dubcac's Avatar
dubcac
I
There aren't any that big....go DSM or aftermarket. I believe the Bseries injectors are 240cc..
Old Oct 29, 2005 | 07:03 PM
Sharpe's Avatar
Sharpe
i figured that none of the honda injectors would be that high since they dont come with turbo from the factory, but what about preludes ? i heard they were around 350 or so.
Old Oct 29, 2005 | 09:11 PM
dubcac's Avatar
dubcac
I
They're not even 300.
Old Oct 31, 2005 | 06:21 AM
AcuraFanatic's Avatar
AcuraFanatic
If you can get some Lucas plate type injectors, those are probably the best on the market and will flow the best at up to 80% duty cycle. Also, figure out how much power you really want to get out of the motor first, if you plan on building it or just plan on running 8-10psi on stock internals. This will allow you to determine what injector size suits you and can save a future switch.
It is much better to go bigger than needed and have an injector loaf all day than it is to have it barely adequete and run at 80%+ duty cycle. Spray patterns and consistancy of fire will become inconsistant and the stress can also lead to premature injector failure.
Just something to think about.
