what gas should i use
Old Oct 12, 2005 | 07:02 AM
EkcivicBeast's Avatar
EkcivicBeast
Default what gas should i use
i was wondering,before i acually complete my ls/vtec build, i am using PCT pistons(JDM),and with the head i will be using i will have sumwhere around 12.3ish:1 compression ratio. i was just wondering if anybody had any suggestion on what fuel i should use, the closes gas stations around me get up to only 93 octane, and i don't think that will halep run my setup good???what can i mix or use to help??? thanks
Old Oct 12, 2005 | 08:11 AM
qtiger's Avatar
qtiger
93 can run PCTs on good tuning. If you aren't 100% confident in your tuner then I would use p73-00 pistons.
Old Oct 12, 2005 | 08:53 AM
EkcivicBeast
do you know some stuff that is taken into consideration when making that PCT and 93 octane work,or a site where i can look up this stuff??? also does anybody know the diameter of those wrist pins for those pistons???
Old Oct 13, 2005 | 06:21 PM
EkcivicBeast
can i use ethanol as a octane booster? and if so how can i find out how much 2 use 2 boost it up 2 my desired octane, i am aware that gasonline has about 15% ethanol???thanks
Old Oct 13, 2005 | 07:19 PM
b16ahybrid's Avatar
b16ahybrid
http://www.gnttype.org/techarea/misc/octanebooster.html
Check that it should help you out.
Old Oct 13, 2005 | 08:33 PM
EkcivicBeast
Originally Posted by b16ahybrid
oh shit thanks just what i needed
Old Oct 14, 2005 | 06:13 AM
b16ahybrid's Avatar
b16ahybrid
No problem.
