leaning twoards boosted b16b
Old Sep 30, 2005 | 12:44 PM
97civicEXVTEC's Avatar
97civicEXVTEC
Default leaning twoards boosted b16b
im starting to look for swaps for my civic..
ive decided to go b16b (civic type r) and boost it down the road.. now my ? is, how low of a compression piston would you recomend for this high reving, high comp engine? any engine+boost suggestions would be nice also..thx
Old Sep 30, 2005 | 12:47 PM
qtiger's Avatar
qtiger
Why in the world would you buy an expensive high compression, low displacement naturally aspirated motor and then build for turbo?
Old Sep 30, 2005 | 01:08 PM
97civicEXVTEC
i thought it was dumb after i posted but didnt feel like editing.. do you think the b16b is a good swap for this car? i was thinking about b16a but i think 185hp will pull a little better then 170ish.. if im gonna do a swap, why not do the bigger an better one right?
Old Sep 30, 2005 | 01:10 PM
qtiger's Avatar
qtiger
A turbo b18b would be better than either b16, and cheaper too.
With turbo you're more concerned about displacement and how much air your turbo is pushing than anything else.
Old Sep 30, 2005 | 04:34 PM
b16ahybrid's Avatar
b16ahybrid
First off what kind of budget are you working with?
How much for the motor (complete swapped and running) and down the road how much do you have for the turbo? What kind of power are you looking to make?
Old Sep 30, 2005 | 06:50 PM
97civicEXVTEC
i can get a 'complete swap' for just under 4 grand and i dont think i will be going fi.. probaly just end up stopping after swap.. i just want something better then the y8, im not looking for a 12 second car..
Old Sep 30, 2005 | 07:15 PM
b16ahybrid's Avatar
b16ahybrid
If 4K is your budget get a B18c1.
The b16 is called the torqueless wonder for a reason.
With 4K you will have enough left over for some mods.
Old Oct 1, 2005 | 03:22 PM
96scD16's Avatar
96scD16
why dont you just supercharge or turbo your y8. I have a supercharged 200 whp y8 with the stock internals and 100,000+ miles and I have been driving this setup for about 2 years without one single problem. And have done everything fairly inexpensively.
96 civic ex
jrsc @ 10 psi
hondata s200 w/ boost option
550 injectors
CAI and Headers
port and polished head
heat wrap
2.25 exhaust w/ test pipe(no cat)
Old Oct 2, 2005 | 07:45 AM
1995Civic's Avatar
1995Civic
I hate ricers
I would not boost a B16B. That's got NA written all over it. LS/Vtec turbo, or B20/turbo, or you could get a little more technical and throw a Vtec head on there....
Old Oct 2, 2005 | 01:58 PM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
96 civic ex
jrsc @ 10 psi
550 injectors
CAI and Headers
heat wrap
+1 on the d series
Go look at www.d-series.org
