B16A1 problem
iam having a problem and iam not sure what it might be............ok iam driving on the highway in 5th gear at 6500 rpm and i feel a bog.....iam like wtf........maybe iam just tired.....so i keep driving.......itdoes it again...iam like dammmmm........it does it like every 10 sec when i accelerate it even more ......doe any 1 know what could be causing this............all the light are working perfect,and the lights doesnt dim when it boggs,,,,,,,,,,,dont know what it could be need some advice on what could be making it bog and hesitate
You must be driving pretty fast at 6500 rpms in 5th gear. :eh:
It is most likely something having to do with ignition timing, so check the base timing to make sure everything is to factory specs. |
i dont even think my car is running right, either..........because it feels like its not going no were.......like its just making alot of motor noise....and i cant even tell how fast iam going because the mph needle get stuck at 80 mph......it feels like its not going no were,,,,,and also once i hite 5500 rpms it takes a while for the rpms to get to 65000 ....
thanks ....appreciate it
Why are you cruising at over 100 mph?
nah, i wasnt cruising i was rushing home,,,,,,,,,,,and on the parkwaytheres like never any cars espesially around 4 in the morning
Does vtec kick in at 5500rpm all the time and ok?
yea it kicks in
No seriously, "cruising" in 5th at 6500, u must've been pulling like 120-130... And to be driving that fast and having ur car bog out is definitely unsafe... Best of luck to u driving that fast, soon or later either u won't be driving or u won't be alive... Be careful... Later |
