91 integra coding 4 blinks
Old Aug 4, 2005 | 10:31 AM
uglyducklyin713's Avatar
uglyducklyin713
Default 91 integra coding 4 blinks
ive got a 91 Acura integra Ls once the car has been running for so long the check engine light comes on and the ecu is showin 4 blinks. ive been told its the crank position sensor or the dizzy cuz its obd1. can someone please tell me how to fix this please
Old Aug 8, 2005 | 04:40 AM
JimBlake's Avatar
JimBlake
Look for loose/dirty/corroded wiring connections to the distributor. You'll need a wiring drawing for '91 if you want to know which wires are for the CKP sensor. But there aren't a ton of wires altogether, so you may as well check them all.
That CKP sensor is down in the bottom of the distributor, and I think it's not available by itself. If you check out the wiring, & rule out those problems, you'll have to buy a distributor.
Old Aug 8, 2005 | 05:17 AM
teg92's Avatar
teg92
WHAT OK YEAH!
whats obd1? the distributor? Cause your car is OBD0
