skunk2 intake manifold
Old Jul 28, 2005 | 01:18 PM
my99blueSi's Avatar
my99blueSi
Default skunk2 intake manifold
i have a 99 si and was wondering if anyone has the skunk2 i/m and what kinda results did u have w/it. also can u feel any difference or not or should u get bigger throttlebody and the same time.
Old Jul 29, 2005 | 05:59 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Get the Edelbrock VictorX. I would if I could go back and do it again.
What all do you have done to the motor currently?
Old Jul 31, 2005 | 03:58 PM
my99blueSi's Avatar
my99blueSi
i have i/e/h,clutch/flywheel,msd ignition,full suspension,aem cam gears,apexi vafc,skunk2 short shifter,17"konig tuner 6's wheels,skunk2 front/rear camber kits,aem fuel rail/regulator and UR underdrive pullies.
Old Jul 31, 2005 | 10:24 PM
qtiger's Avatar
qtiger
Since you just have i/h/e, you won't gain much from a manifold change.
Old Aug 1, 2005 | 06:10 AM
teg92's Avatar
teg92
WHAT OK YEAH!
you probally wont feel a difference
Old Aug 1, 2005 | 03:32 PM
mberndt's Avatar
mberndt
Hey man,
I used to have a SKUNK2 IM on my car, when it was N/A and had the orig B16A head on it...
You will feel a slight difference above like 7K, it will pull stronger to redline, assuming u got 4-1 header...
U should get TB cause IM's dia is bigger, so it matches SKUNK2 IM
later
